Disables MSRP and removes all configuration. If a list of ports is specified, MSRP is disabled and the related configuration is removed only on the ports and the system-wide MSRP configuration stays intact.
| msrp | Multiple Stream Registration Protocol. |
| port_list | List of ports in the switch. |
| all | All the ports in the switch. |
N/A.
Use this command disable MSRP and remove all configuration. If a list of ports is specified, MSRP is disabled and the related configuration is removed only on the ports and the system-wide MSRP configuration stays intact.
unconfigure msrp unconfigure msrp ports all
This command was first available in ExtremeXOS 15.3.
This command is available on all platforms that support the AVB feature and that have an AVB feature pack license installed. To see which platforms support AVB and for information about obtaining a license, see the Switch Engine v33.1.1 Licensing Guide .
